• Need Support? Go to the Support Area!
  • Comment Bot v1.2.6 Released!
  • Social Media Bot v5.5.3 Released!
Social Media Bot Settings Guide v5
#1
[Image: Client-Management.png]
Client Management
Here you can open clients. Ultra has 10 available clients, Pro has 2 and free has 1.
[Image: Global-Settings.png]
Global Settings
1. Enable / Disable if the bot should automatically start all clients that are properly configured (= at least opened once).
2. Enable / Disable if the bot should start with Windows (turning this on will create a registry key for the current user)
3. Enable / Disable sounds for when a task completes, the bot stops or an error occurs (default sound is disabled)
4. Enable / Disable popup notifications / warning / errors. It is recommended to leave this option turned on, unless you are running the bot unsupervised on VPS or similar with auto start and start with Windows enabled.
5.  This option will increase the amount of memory the bot can use (Java 8 64 bit only!). This should be activated when running multiple clients and the bot gets stuck on tasks. You should always install Java 8 64 bit if you pc supports it!
6. Opens the update log, so you can see what has been changed in the latest updates.
[Image: Overview.png]
Overview
1. Contains the status of the bot and the current task that is running
2. Press the start button to start the task list
3. Press the stop button to stop the bot when it is running
4. Press the pause button to pause the bot when it is running
5. Press the skip button to skip the task that is currently running and to go to the next task
6. Logs all events of the bot
[Image: Account-Management.png]
Account Management
1. Select the service for which to save the username & password
2. & 3. Fill in the username & pass
4. Set the account as enabled or disabled (disabled accounts will not be used to login)
5. Pressing save will save the account to the list (will override existing if the service and username are the same)
6. The list of currently saved accounts
7. Select an account in the list and click this button to delete it
8. Deletes all the accounts in the list
9. Show the passwords in the accounts list or show them as ******
10. Save the list of accounts in a custom location
11. Load the list of accounts from a custom location
[Image: Task-Settings.png]
Task Settings
1. Select on which service you want to bot (AddMeFast, Like4Like, ..)
2. Select which task you want to bot (Facebook Likes, YouTube Subs, ..)
  - (Other) Break task: Pauses the bot for the set amount of minutes
  - All: Adds all possible tasks for the selected service for the given amount of minutes (the minutes can not be set to 0 for this)
3. Set the runtime for the task in minutes. Setting this to zero (0) will run the task for unlimited time.
4. Click this button to add the selected task to the list
5. Shows the current task list (note that tasks are drag-droppable)
6. Select a task in the task list and click this button to remove it (keybind: Delete)
7. Clears the complete task list
8. Saves your current task list as default so it will be automatically loaded next time you run the bot
9. Saves your current task list in a custom location
10. Load a task list from a custom location
11. Customize the settings of the selected task
12. Select a task in the task list and click the up/down buttons to move it up/down in the list (Keybinds: Shift+Up/Shift+Down)
13. Select a task in the task list and click the top/bottom buttons to move it to the top/bottom of the list (Keybinds: PgUp/PgDn)
[Image: Client-Settings.png]
Bot Settings
1. Indicates if the bot should automatically stop after a certain runtime in minutes
2. Indicates if the bot should automatically stop after gaining a certain amount of points
3. Indicates if the bot should repeat the task list, meaning when it reaches the end of the list, it will start again at the top.
4. Sets the amount of times the task may fail before it should be cancelled
5. Sets the minimum amount of points that a task should give, if the tasks gives lower points than that value 3 times in a row it will be cancelled
6. Indicates if a delay between tasks should be used (For example between each like)
7. Sets the delay that should be used before closing the window in milliseconds, after clicking like/sub/.. (If AMF/L4L/.. tells you that you are closing the window too fast, try to increase these values)
8. Sets the delay that should be used after closing the window (before checking how many points have been gained)
9. Indicates if the bot should delete all cookies when closing (use carefully as this means your accounts will all have to login again)
10. Indicates if a proxy should be used and which IP/Port/User/Pass to use for the proxy. (DO NOT use public proxies as this will get your accounts banned - User / Pass are currently not available until further notice)
10. Saves the current settings to be the default (and loaded on startup)
The following is a sample task list that you can download and load into the bot, it is meant to be used for short runs (= once a day):
Donations accepted:
BTC: 3NDVhUA8gD1Ju2v6NfFP5z8pUbd7WQ9KUB
ETH: 0x7941eD3086127EC961326Ea1EBa51d61612f708B
PayPal: Click here
#2
Amazing , Well done . :heart:
Forum Jump:
Users browsing this thread: 1 Guest(s)
